Primary render object when 2 objects on top of each other
   3082   2   0
I have 2 objects on top of each other, they are same shape at same position. I wonder if there is a way to tell Mantra which object is the primary one, so Mantra will render the primary one instead of the other. Something like render priority?
I have a simple example file. In my test render, it always renders the red one. I would expect there is a way to render just green, but I have to have them both in forced object, renderable, and no shader change because the setup I have now.
render_priority.hipnc (155.8 KB)
Define what you want to render in the mantra rop > objects and just list it . Remember the default “ * ” = consider rendering everything that's displayed
Rob
Gone fishing
Thanks for reply. circusmonkey
Because of the current setting I have, I can't change the objects in the ROP now. They have to be forced objects and renderable objects.
