Hello everyone. I'm pretty new to Houdini and I have to say I'm pretty confused as to why there is no edge slide operator. All internet searches I've run seem to point to a plugin that hasn't been updated since Houdini 10:
http://www.fourthwall.ndo.co.uk/HT_HDK_PointSlide.html [fourthwall.ndo.co.uk]
I'm guessing it doesn't work anymore, since after installing I don't see a new SOP.
It strikes me as odd because Houdini's built in Edge Loop SOP draws a nice projection of a loop which it then turns into a polysplit. How hard would it be to create a SOP that does the first part pretty much the same and then moves the points accordingly rather than polysplit?
Does anyone know of a solution that isn't outdated?
Point and Edge Slide?
4849 1 1-
- Kevin Soucy
- 1 posts
- animatrix_
- 5100 posts
I uploaded mine to Orbolt before the holidays, so waiting for it to be approved
In any case, if you can wait for a couple of days, it should be available here:
https://www.orbolt.com/asset/animatrix::slideEdges::1.00 [orbolt.com]
