Hi, I'm trying to set a size stamp variable in a copy SOP which is dependant on the input of a switch. I've tried
set -g size = 0.0;
if(chs(“../switch_road_type/input”) == 0)
size=point(“../scatter_on_blocks”,$PT,“ptarea”,1)
else
size=point(“../scatter_on_islands”,$PT,“ptarea”,1)
return size;
however it gives the error Unable to evaluate expression (Sytax error (…/name_of_copy_sop/val1)).
Any help would be greatly appreciated.
how to use switch inputs in expressions
6511 3 0-
- Emily Brut
- 2 posts
- animatrix_
- 5100 posts
Firstly you need to encapsulate the whole expression block in {}:
size = 0;
if (ch(“../switch1/input”) == 0)
size = 1;
else
size = 0;
return size;
Declare the variable as:
size = 0;
You can also directly return by using multiple return statements. It will early return.
Also use ch, not chs, as it's not a string.
A more Houdini-like approach IMO would be to use a Null and reference this in the stamp variable without using additional logic. This way no matter which input is used, you can read the same attribute from the Null node.
size = 0;
size = 1;
else
size = 0;
return size;
size = 0;
- Emily Brut
- 2 posts
Thanks for your reply. I've tried your suggestion using
size = 0;
if (ch(“../switch_road_type/input”) == 0)
size = point(“../scatter_on_blocks”,$PT,“ptarea”,1);
else
size=point(“../scatter_on_islands”,$PT,“ptarea”,1);
return size=point(“../scatter_on_islands”,$PT,“ptarea”,1);
but it sill gives a syntax error: Unable to evaluate expression (Syntax error - extra tokens detected in expression (../name_of_copy_sop/val1). Do you know why this might be?
Forgive me if i'm missing something obvious too, but with the Null node method, surely i'll have the same problem that depending on which input is selected, it will need to contain different values?
size = 0;
else
- animatrix_
- 5100 posts
When you use return, don't assign to the value in the same line. So do this:
size = 0;
else
return size;
That should work.
With the Null method, you wouldn't have to but I assume you are generating the same attribute you are looking for in both branches. Something like this:
Though there are a lot of unknowns that can make this not as reasonable, such as whether you are not storing the result in the same attributes, or you need completely different logic to generate values based on the input number, etc.
size = 0;
else
return size;
That should work.
