heres the link to other postings...on same issue.
   3943   5   0
Hi there,
heres the link to other postings…on same issue.
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=30796 [sidefx.com]
R.
Is this what you're after?
Just moved the render flag to the preview node thingy
oceantests_146Edit.hipnc (945.3 KB)
Screen Shot 2014-02-13 at 12.51.08 pm.png (421.0 KB)
Hi there,
Thanks for that - i've just picked it up….
being a newbie still…can you clarify answer answer …render flag to preview thingy…thanks.
R.
The Display flag is blue, the render flag is purple, set on each node, Try selecting the node and pressing ‘1’ or ‘2’
Please read
http://www.sidefx.com/docs/houdini13.0/nodes/sop/ [sidefx.com]
It really helps to go through the interface basics before creating an ocean in cgi.
FWIW. SideFX's next tutorial should be “Using The Manual”
Edit: changed instructions
Some testing; the tutorial works in the commercially licensed HoudiniFx, though, there appears to be an issue for the non-commercial license as the texture is generated for pic instead of picnc
Fixed scene attached, tested on HoudiniFx 13.0.321 os OsX
Hope that helps
Screen Shot 2014-02-13 at 3.36.44 pm.png (356.6 KB)
OceanTest.hipnc (1.8 MB)
Hey Marty
Many thanks for your support last night - can't say how much that has helped…often these hiccups get in way of actually getting on with stuff….so I can now proceed to the next hiccup.
Thanks again, you have been of genuine help.
Regards
Rob.
