Baking uv/texture
   7401   8   2
hello everyone
i am trying to bake uv with texture in houdini, in png format
which i want use in photoshop
actually i dont know the procedure for baking textures in houdini
i added a mantra node and in RENDER tab i mentioned the
UV render object and the UV attribute the render image is not correct, how to get a flat image without this black shading .
can anyone guide me how to bake uv/texture in houdini
thanks in advance
Ravikumar
One important thing is you should save UV in the Vertices (By default is Points).
Check this Topic for more detail :
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=28279&highlight=Bake [sidefx.com]
Check Attached File :
JKBake_UV.zip (313.3 KB)
Rabiee.Sadjad@Gmail.Com
Joker386
thank you for your help still i have some doubts
the geometry which i am using is imported from maya when i viewed in detail view the vertex attribute is there please tell me how can i save UV in vertices when we import geos form maya which already have UV assigned to geometry
i am attaching houdini hip file if possible please go through it and guide me how to corret this problem.
thanks in advance
tex_bake.rar (350.2 KB)
Ravikumar
But UV for Objects that imported from Maya are stored in the Vertices by Default !
I checked your file and the Airplane's Texture Baked correctly ! (Check Attached File)
However if in the special case you wanna convert Point's UV to Vertex UV ,So you can use “AttribPromote SOP” :idea:
Check Attached file :
JK_tex_bake.rar (516.7 KB)
Joker386
yeah i got it now, Thank you for taking time to solve my problem, i really appreciate it.
Ravikumar
ravibr
Joker386
Your welcome my friend
hello can one tell me more about how to get a flat image from an UV set?
In the “out” network, I didnd't find an “uv render” node…
Houdini gamboler
So how do you send your UV's to Photoshop? So far I'm using the “print screen” on my keyboard but there must be a more elegant way…
Houdini gamboler
hi,
right click on SOP then SAVE > texture UV to image..
greetings
Fred
