VC9 or VC11
8864 6 0-
- torwart
- 52 posts
- edward
- 8094 posts
If you're plugins built with the HDK (houdini dev kit), then you need to make sure that the version of Houdini you're using matches what the plugin was compiled with.
If you aren't using any plugins, then use the VC11 version. As far as I know, VC11 generates faster code than VC9. There are also plans to drop VC9 for the next major release.
- Anonymous
- 678 posts
- edward
- 8094 posts
Yes, we have 32-bit VC11 builds in the development trunk. If the 64-bit Unity game editor ever gets released, then we will gladly drop 32-bit VC11 as well.
I'm not sure what you mean by “problem of 64-bit stability” since the Unity plugin is only available as 32-bit, because the Unity game editor is only 32-bit.
- Anonymous
- 678 posts
edward
Ups, TWOD was saing this about Unity. I thought that you made some magical bridge that allows you to use 64-bit extension in 32-bit program
http://forums.odforce.net/topic/18872-public-preview-of-houdini-engine-plug-ins-for-maya-and-unity/ [forums.odforce.net]
edward
I jope that it will be released soon because I'm left with 2012 now and can't use any of my HDK tools with Unity because I can't compile for 32-bit. And I'm too lazy to install Windows SDK
- edward
- 8094 posts
mantragora
I think he was referring to the 64-bit Unity game editor work-in-progress.
- Anonymous
- 678 posts
edwardmantragora
Yeah, that's why I said “Ups”
