Impossible to Export Data from Fur Node ?
   3138   1   0
Hi
I'm trying to dump the curve data from Houdini and I entered the “/obj/torus_object1_fur_/fur” and found the “create_fur” node, but once I tried to connect a Alembic node to it it reported me the error info “Failed to modify the node or parameter because of a permission error.” Is there any body know how to dump the curve data ? Thanks !
You mean the ROP Alembic Output node? Are you using a commercial edition?
