I'm trying to import some geometry from a mapped drive, but everything is greyed out and unclickable. If I copy the files to my local hard drive, I can click on them. I still cannot import .lwo files though - which is what I'm really after - as I just get a 'Unable to read file ' error.
Any ideas?
Cannot import any geometry at all from network location
4235 11 1-
- Anti-Distinctlyminty
- 271 posts
- eetu
- 607 posts
Any ideas?
I ran into this as well, it ended up being dependant on which unix user owned the directories/files on the linux fileserver. This was through Samba.
- 271 posts
- eetu
- 607 posts
Any idea why the *.lwo files are just failing to read even if they are local?
Houdini's lwo reader is ancient, it needs the objects to be “pre-6.0” in flavor.
There is a very thorough lwo reader at http://forums.odforce.net/topic/15565-lightwave-lwo-reader-sop/ [forums.odforce.net]
- 271 posts
- eetu
- 607 posts
The otl is attached on post #23 (second page).
http://forums.odforce.net/topic/15565-lightwave-lwo-reader-sop/?p=101387 [forums.odforce.net]
- 271 posts
- 271 posts
- eetu
- 607 posts
It can be a bit picky, but mostly it's just warnings.
Have you checked the timeutil issue on the last page of that thread?
Instead of installing it, you can comment out all timeutil stuff from the source.
(search for ‘timeutil’ and ‘parser’)
Another thing it chokes on is if a point attribute has a ‘-’ in it.
- 271 posts
- 271 posts
…and now getting this:
File “<stdin>”, line 1, in <module>
File “opdef
Sop/lwo?PythonModule”, line 4190, in onFilename
File “opdef
Sop/lwo?PythonModule”, line 4265, in LoadLwo
File “opdef
Sop/lwo?PythonModule”, line 79, in __init__
File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.343\python27\lib\logging\__init__.py”, line 902, in __init__
StreamHandler.__init__(self, self._open())
File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.343\python27\lib\logging\__init__.py”, line 925, in _open
stream = open(self.baseFilename, self.mode)
IOError: (2, ‘No such file or directory’, ‘C:\\tmp\\LightwaveSOP.log’)
File “opdef
Sop/lwo?PythonModule”, line 4190, in onFilenameFile “opdef
Sop/lwo?PythonModule”, line 4265, in LoadLwoFile “opdef
Sop/lwo?PythonModule”, line 79, in __init__File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.343\python27\lib\logging\__init__.py”, line 902, in __init__
- eetu
- 607 posts
