voronoifracturepoints exterior?
   4509   6   1
hello.
in the voronoifracturepoints-sop, what is the “exterior” scattering of points good for?
i understand that the SDF/IsoLevel is being used for scattering inside and on the surface, where the voronoi pieces are being generated.
but outside? where are these pieces?
i am a houdini noob….
thank you in advance
fuat
Fuat Yüksel
maybe it anwser your question but look at this video:
http://www.sidefx.com/index.php?option=com_content&task=view&id=2350&Itemid=344 [sidefx.com]
it's shows also the voronoi sop.
I usually use this for making group of the small pieces inside of the Big pieces !
JKVorooni_Exterior.hip (182.1 KB)
Rabiee.Sadjad@Gmail.Com
thank you very much, Joker.
i dont know why but your scene makes my Apprentice crash when opening it.
i will try nevertheless.
but from the screenshots you attached, i get a better understanding, thanks a lot. one question though: it seems like the blue/exterior scatter points affect the parts inside the geo. is this true? and if yes, how? i thought they are outside?
or do i miss somehtin crucial here?
fuat
EDIT: i managed to open the scene and had a look inside. i guess it has something to do with the “impact offset” (which is set to -1.55), right?
that would make sense to me. am i right or totally wrong?
Fuat Yüksel
ok, got it.
outside means not outside of the geo but outside of the metaballs which are created for generating the cells.
thanks anyway.
fuat
Fuat Yüksel
fuat
ok, got it.
thanks anyway.
fuat
Yes , Exactly !
Also to achieve best result you should set “impact offset” correctly :wink:
yes, thank you Joker386.
fuat
Fuat Yüksel
