Hi All,
I am trying to convert a Houdini matrix to Blender matrix so that when the matrix is applied in Blender the camera faces the same direction and is in the same place as it was in Houdini.
Does anyone have any python code to achieve such a task?
I am fetching the Houdini matrix like so…
hou.node(“/obj/cam1”).parmTransform()
This produces a string like this.
I can blindly create a matrix out if it in Blender but when I assign that matrix to the Blender camera it just sits at world origin although it does have some rotation applied.
s = "[, , , ]"
ms = eval(s)
mtx = Matrix(ms)
ob_camera.matrix_world = mtx
If I extend that code by manually extracting the location from the Houdini matrix the Blender camera will move to a new location but it does not match the way the Houdini camera looks.
ob_camera.location.x = 5.32776
ob_camera.location.y = 2.57303
ob_camera.location.z = 7.33473
I am looking for some kind of “black-box” python function that will accept a Houdini matrix and return a valid Blender matrix. Like shown in this math image.
[python]Convert Houdini Matrix To Blender Matrix?
6604 4 0-
- Enivob
- 2658 posts
- pezetko
- 392 posts
Blender uses column-major storage for matrix but Houdini uses row-major.
So for getting right position you need transpose that matrix.
Something like:
import mathutils
mtx.transpose()
Also don't forget that in Houdini is Y-axis up but Blender is Z-up, so you need to do conversion somewhere.
Something like:
import mathutils
mtx.transpose()
- Enivob
- 2658 posts
Thanks for that line of code. It does seem to help but the x axis is still wrong.
Do you know how to rotate a matrix along the x-axis using the world origin as the pivot point?
Here is the code I currently have working.
s = "[, , , ]"
tmp = eval(s)
mtx = Matrix(tmp)
ob_camera.location = [mtx,-mtx,mtx] #Flip Z and Y axis.
mtx.transpose()
It seems I have to transpose the matrix after I assign the location.
s = "[, , , ]"
tmp = eval(s)
mtx = Matrix(tmp)
mtx.transpose()
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- pezetko
- 392 posts
You cannot just switch axis in translation part of transform matrix, you need do transformation on whole matrix.
You need inverted task of this:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=22279&view=next&sid=65fb6e0ccd2b297e3082811ce081a01b [sidefx.com]
And some info about that:
http://blog.duber.cz/3ds-max/the-transformation-matrix-is-useful-when-understood [blog.duber.cz]
- Enivob
- 2658 posts
Thanks, I got it to work, but I am still not sure I fully understand the Matrix manipulations.
import bpy, math
from mathutils import Vector,Matrix
def applyTransform(sMatrix, passedOb):
if passedOb != None:
tmp = eval(sMatrix)
mtx = Matrix(tmp)
passedOb.location = [mtx,-mtx,mtx] # Flip Z and Y axis.
mtx.transpose() # From BL Stack user.
rot_x_neg90 = Matrix.Rotation(math.pi/2.0, 4, ‘X’) # From Kastoria.
passedOb.matrix_world = rot_x_neg90 * mtx # From Kastoria.
# Matrix string from Houdini object.
s = "[, , , ]“
ob = bpy.data.objects.get(”Camera")
applyTransform(s,ob)
import bpy, math
tmp = eval(sMatrix)
mtx = Matrix(tmp)
s = "[, , , ]“
