I have been looking into changing the point numbers on a geometry and found the Sort node very useful but I'm wondering is there a way to define which point you want to be which number?
In the image I am trying to show where I would like the points 0,1,2 to be defined along the geometry. Is that possible? And if so could any one please let me know how. Thanks.
Define point number
5368 3 1-
- sessionbeer
- 39 posts
- tamte
- 9380 posts
just create an attribute containing your numbers (or at least the same incrementing order)
then Sort SOP/By Attribute
but keep in mind that resulting point numbers will always be unique integer numbers starting at 0 with increment of 1, so if your source attribute does not follow these rules, actual numbers will be different, however the order will be used from attribute
- sessionbeer
- 39 posts
Thanks your reply Thomas. I'm still very new to houdini and am trying to understand it's different workflow from other packages. From your reply, I still don't understand how I define where I would like specific point numbers to be? Do I make an attribute from a point selection? The whole promote attribute in houdini is a bit confusing to me at the monment but I'm working on it. Thanks again for your reply.
- danwood82
- 48 posts
Depending on what purpose you actually need this for, it would usually be best to try and define the point order procedurally somehow using a VOP SOP node. (VOP SOP is pretty much the go-to node to process any data into any other data)
If you want to manually specify a point ordering, I knocked up a quick VOP SOP containing a bit of inline code to parse a string of numbers and create an integer attribute from it, which then gets passed into a sort node. Not sure if it's the most elegant way, but it's *a* way :-)
