Mantra Black refraction near objects with Fresnel
   12936   10   3
Hello guys !
I have a problem with Mantra, when I'm rendering a simple mantra surface shader with Reflections On and Refractions On and Fresnel Blending Ticked, my refraction is black near objects.
If I unticked Fresnel BLending, it works. So what I need to know and do to solve my problem.
Thank you very much if you can help me.
Reflection + Refraction :
Refraction Only :
Debug_Shader_refraction_black.hip (1.1 MB)
That's because Houdini doesn't render shadows for refraction, Transparent Shadows option in the light setting only work for opacity , Not refraction !
So you have two solution :
1. Add causticlight for generating caustic.
2. Use Fake caustic option , to use this option go to mantrasurface parameters –>Opacity–>turn on Enable Faux Caustics
Rabiee.Sadjad@Gmail.Com
Thank you so much Rabiee for your quick and perfect reply.
I don't know why it doesn't work with the causticlight, but it works perfectly with “Enable Faux Caustic”
PS : Do you have an idead about how can I avoid the little “noise” of my sphere on my render ? (you can see it on the first picture) My : Mantra Sample is set to 8 x 8
But Caustic Light working perfectly on your project :!:
Just add Caustic Light from shelf tools and tab Render !!!
About your second question , You should just increase Sampling Quality parameter in the envlight settings.
Increasing pixel sample is very slow in rendering :wink:
This is your project with Caustic Light and without noise :wink:
Of course using Caustic Light is so slow in rendering .
JKdebug_shader_refraction_black_119.zip (102.9 KB)
Thank you for the file and the tips about increasing Sampling Quality parameter in the envlight settings.
It's Crazy. When I launch you file, the Caustic Light works like a charm. If I delete it, and create antoher one with the shelf tool, it works fine.
Therefore, in my original file, if I create a Caustic Light like above, anything change. It doesn't work.
Did you change something else to integrate perfectly the Caustic Light ?
Have good day
Edited by - Sept. 9, 2014 05:54:23
No , I just add a caustic light from shelf without any special setting !
Test it in the another project , Also use another Mantra node with default settings , Maybe you changed some special parameter in the Mantra node :?
I have deleted my Mantra PBR, re create a new one with same parameters and now it's good :shock:
Thank you for everything !
Hate de voir ce que tu nous prepares
https://vimeo.com/obreadytom [vimeo.com]
Salut Tom je bosse sur un projet perso de rapide/whitewater que je posterais dans pas trop longtemps j'espère
Ah énorme !
Je suis aussi sur une scène du genre actuellement mais bon j'ai moyen le temps Au fait tu seras à la soirée “graphix” (si c'est bien le nom) le 18 ?
