point attributes in maya
   6408   2   2
Hi, there. I have some point attributes on the geometry generated by an SOP HDA. Is there any way to get those on the mesh shape created in Maya? As far as I can tell only P, N, uv, Cd, and Alpha are supported.
Peter.
Unfortunately, no, because Maya doesn't have generic attributes like Houdini does. Each mesh can only contain a fixed set of attributes. Particles is probably the only exception where you can have arbitrary attributes attached to particles.
Andrew / アンドリュー
It seems like attributes could be supported in some fashion. For example, the alembic importer adds typed attributes to the shape node for the per-point data. This data survives intact when exported to alembic out of maya.
