Hi
I wanna blend two different Pyro with different Voxel Size and scale with together , Even If I can fade out first one and fade in second one would be great !
Of course I tested it with Blend Shapes and Sequence Blend nodes with turning on Blend Voxel Data option , They are works great on simple Volumes such as ISO Offset node , but that seems they are only works perfectly on volumes with same voxel size and scale !
I think they use voxel size and scale of the first input for second input too and that's not what I need !
How I can blend two volumes or even make dissolve effect between them ?
thanks
Volume Blending
3962 3 1-
- Jack.N
- 72 posts
- Sadjad Rabiee
- 1391 posts
- Sadjad Rabiee
- 1391 posts
- Jack.N
- 72 posts
