Unable to export .obj/.dxf files
   4192   3   2
Hey All,
I am facing problems with reading/writing formats other than .bgeo. I use the file SOP to import/export to .obj or .dxf files and I get a file with no data(0 kb files). I use Houdini 13.0.509 and have successfully read/write .obj and .dxf using this same version before.
I cannot understand what has changed that suddenly wouldnt allow me to read/write other geometry formats. I need your help. Thanks.
Cheers
ViSiKa
vigneshkaushik
I use the file SOP to import/export to .obj or .dxf files .
What about using ROP Output Driver !?
Or using Right Click Menu –> Save Geometry… ?
Rabiee.Sadjad@Gmail.Com
Using right click-save geometry produces only a 0kb file.
Cheers
ViSiKa
vigneshkaushik
That's really strange , becuase you said it worked perfectly on previuse versions !
So maybe this is a BUG in Houdini with your OS or Hardware , however submit this to company :
https://www.sidefx.com/index.php?option=com_content&task=view&id=768&Itemid=239 [sidefx.com]
Also install older Houdini builds and check it again.
Sorry for that man , I really don't know what's your problem exactly :roll:
