Hi everyone
I have been strugling with a very strange behaviour of the name attribute being passed over primitves or not when unpacking.
When a copy sop is packing geometry and then the name attribute is writen with a attribwrangle (or a simple adattribute) this name attribute is not transfered to the corresponding primitives when unpacked.
When a copy sop is not packing geometry and then the paxked geometry and the name attribute are handled with an assemble this name attribute is transfered to the corresponding primitives when unpacked.
Third case following the second setup, when the name attribute value is overided with aan attribWrangle the original value is retrieved when unpacking????
Well it seems to me that the real name attribute is hiden somewhere in the guts of the packed geo but should not we have acces to this name and be able to update it and be abble to retrieve it properly when unpacking?
Any thought, wisdom or even wizardry to help me out?
THX
Packed Geometry name attribute puzzle
4537 2 1-
- NAHASSIA
- 125 posts
- tamte
- 9384 posts
without looking at the file:
no wizardry
sadly Unpack SOP currently doesn't transfer any attributes back, so no name attribute from packed points is transferred to unpacked geo, as you experienced with packed copies
the assembled name attribute is simply packed inside (if Create Name Attribute is on or if it has existed on geo before)
so assemble creates primitive name attribute on original pieces, then pack them and creates another point name attribute for pieces
if you unpack that, the name on points of packed prims is lost and all you can see is the name attribute that existed on prims of geometry that was packed inside, therefore it can differ from your modified name
no wizardry
- NAHASSIA
- 125 posts
