MAYA 2014/15 and Houdini Engine
   3911   1   1
Has anyone experienced textures not showing up in Maya 2014 through Houdini engine?
As a test, I downloaded the Side Effects Spaceship OTL. In Maya 2015, the textures show up in the viewport, but not in 2014. Is that something that is known, or being looked at?
Thanks,
–Carlos
Hm, which OS are you on? Do you see a texture file node attached to the material created in the scene? The asset node will write out texture files into the sourceimage directory in the project directory. Do you see the texture file there?
Andrew / アンドリュー
