Hi
I have installed Houdini v13 and I really need to run “HOT ocean toolkit” on this version . and as far as I know it is not released for the 13 version and there is only a compile for it which could be run on LINUX and MAC OS .
but I am a windows user.
Does any body have a compile.bat file for this issue or could you help me in other ways ?
thanks
how to install HOT(houdini ocean toolkit) in houdini v13.0.4
8941 8 1-
- samran Egon
- 14 posts
- mandrake0
- 655 posts
- samran Egon
- 14 posts
- anon_user_37409885
- 4189 posts
- samran Egon
- 14 posts
The Houdini Ocean Toolkit (HOT) for rendering deep ocean waves(algorithms of Jerry Tessendorf) in houdini 13? :shock:
im trying to install the tookit about 6day :cry:
this a toutorial for install the toolkit bot very complex for me:
http://anusf.anu.edu.au/~drw900/houdini/ocean/docs/ [anusf.anu.edu.au]
thanks
thanks
- 4189 posts
OceanFx should be fine; check out the intro videos
https://www.sidefx.com/index.php?option=com_content&task=view&id=2659&Itemid=261 [sidefx.com]
- samran Egon
- 14 posts
- 4189 posts
What effect are you looking for? There is another tutorial that has sounds like what you want
https://www.sidefx.com/index.php?option=com_content&task=view&id=2700&Itemid=261 [sidefx.com]
- samran Egon
- 14 posts
this video is seem to project that i have make
http://vimeo.com/92284627 [vimeo.com]
i think the base of ocean created bu ocean surface and displacements and at bottom of boat , particle splash made the interaction between boat an ocean.
