hi
i justed started testing Houdini14 (Apprentice License) and wanted to generate an asset for maya
no matter what i do the generated files are not showing up in maya
i downloaded an example file from he asset-store wich worked fine
the problem might be that i only can generate hdanc files and not otl files
can someone help me please
thanks!
beginners question generating otl for maya
4472 1 1-
- verstaerker
- 1 posts
- awong
- 818 posts
Ah, your guess is correct. The assets that you create from Houdini Apprentice are “non-commercial” assets. At the moment, they are not allowed to be loaded into Houdini Engine, which is for commercial use.
However, there is a way to convert them into commercial assets! If you upload and share your non-commercial assets onto Orbolt (www.orbolt.com), our online asset store, then you can download them back as commercial assets. You can then load those assets into Houdini Engine!
Andrew / アンドリュー
