Giving POP particles an initial spin
   15922   4   0
I'm trying to give particles in my POP Network an initial spin (angular momentum), but can't seem to figure out how.
I connected a POP Wrangle node to my POP Solver and experimented with vex code.
@torque = {x, y, z};
…works and the particles start spinning. However I'd like to have them start with a constant angular momentum instead and not apply any angular forces after that.
I thought I had found the right parameter with @w, for which the documentation states:
Angular speed of the particle. This can be thought of as a vector giving the rotation axis with its magnitude being the spin rate. Spin rate is in radians per second.
Alas, neither of the following lines have any visible effect:
v@w = {x, y, z};
v@targetw = {x, y, z};
Are they read only variables maybe?
Let me know if what I want can be accomplished, or if I have to go with torque. Thanks!
Bump, anyone? Is a time-constrained torque the only option?
Particles need to know that they have to compute torque.
So set v@torque directly on emitter (in SOPs):
v@torque = set(10,10,0);
Or initialize v@w on emitter in SOP like you do:
v@w = set(10,10,0);
And in DOPs add poptorque and set it's Amount to 0 (so it takes initial v@w).
Thanks pezetko, adding the POP Torque does enable the w parameter for the simulation!
the only thing that's important is having orient on your particles if you want w to have any effect
so if you initialize orient alongside of your w in sops, then you don't have to do anything else in dops and your w will be applied
v@w = {10,10,0};
p@orient = {0,0,0,1};
