The object does not rotate around the pivot point
   3403   2   0
I'm new to houdini. I have a problem with the pivot point of a box.
I assume box should rotate around its pivot point by default. This is the way it is in 3dsmax. But somehow it doesn't follow my assumption. I have included the image below which illustrates the issue.
Any help is really appreciated.
I'm also new in Houdini. I think you need to move the pivot point to box edge and then apply the rotation.
In the attached file, I tried to do a rolling cube. Play animation and discover the nodes…
RollingBox.hipnc (58.0 KB)
For reference:
http://forums.odforce.net/topic/95-silly-challenge/ [forums.odforce.net]
