Create Point Group not accessible in AttributeVOP
   4183   3   0
The “Create Point Group” is in help page
But In the new VOP which is AttributeVOP, I cant acess the “Create Point Group” and “Add Point to Group”
sideFX removed the Vop Sop from default
What is the alternative for “Create Point Group” and “Add Point to Group” inside AttributeVOP?
The only way I found is reactivate the legacy Vop Sop node in OPcustomize
parafuso3d .
Use a bind export set to integer.
Name the output group_Groupname.
Same goes for the wrangle nodes
if(@ptnum < 10){
i@group_myGroup = 1;
puts point 0-9 in the group named myGroup.
nice trick mawi
Thanks a lot
U can also use addAttribute and set mode to group
