As the title says, I rendering though a glass sphere and need the alpha of what's inside…
any ideas?
Getting Alpha in refraction with mantra?
5089 5 2-
- cgcris
- 67 posts
- Sadjad Rabiee
- 1391 posts
- cgcris
- 67 posts
- sl0throp
- 258 posts
Really not quite sure what you want an alpha of, but if you have an object inside the sphere, and you want a way of extracting a matte to be able to tweak whatever is inside of the sphere in post:
Just create an attribute called matte on the object, make it a vector, and set the x channel to one. In your shader, you will need to bind and export that attribute and add an image plane in your rop called matte, and set it to type vector. That way you should get a mask in the red channel in your image plane called matte.
If this is not what you are looking for, can you clarify a little…
- cgcris
- 67 posts
Thanks for your reply.
Yes that's exactly what I need the alpha of an object that's inside a glass sphere.
However the method you are suggesting implies I pipe a parameter via the “interior objects” shader, when is actually the sphere outside who has the refraction shader.
I've tried it anyway but it doesn't work, since it wont consider refraction.
any other ideas?
any other ideas?
- eetu
- 607 posts
Not trivial, but think you need to setup your shaders to pass information between each other, http://www.sidefx.com/docs/houdini14.0/vex/functions/trace#idm47446624006848 [sidefx.com]
