RBD and Deformed Collision Object
4530
2
0
- tomtm
- 133 posts
I have a simple Grid Polygon and applied a mountain deformer.
I defined it as a static object to use as a collision object.
But the sphere which is a RBD does not interact with the displacement ,
instead it just collide with the normal grid shape.
So the deformer does not collide… is there something special I must know.
Tom
- Nima
- 471 posts
hello.
probably your grid polygon not have thickness.
set your ground plane as terrain object from rigid body shelf instead of static object.
- tomtm
- 133 posts
thank you! yes, you are right, it was the missing terrain operator from the rigid tab!
Greets Tom
