hou.GeometryViewport
   4104   2   1
I want to use python to center the current viewport. I've tracked it down to
hou.GeometryViewport().homeAll()
File “<console>”, line 1, in <module>
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.470/houdini/python2.7libs\hou.py”, line 39628, in __init__
def __init__(self): raise AttributeError, “No constructor defined”
AttributeError: No constructor defined
but that doesn't work. I'm not sure what the proper syntax is.
I've also tried:
import toolutils
viewer = toolutils.sceneViewer()
hou.GeometryViewport(viewer).homeAll()
TypeError: __init__() takes exactly 1 argument (2 given)
Thanks in advance.
/R
lights, camera, … life …
import toolutils
viewer.viewports().homeAll()
The “viewer” will be a Scene Viewer pane (if one is open). But the scene viewer pane has four viewports (even if you are not in quad view, the four viewports are always there). In my case, my perspective viewport was the third one in the list returned by “viewer.viewports()”. You will probably want some logic in there to choose which viewport to home (or you could loop through and home all of them).
Hope that helps,
Mark
ok, looping through works fine.
Tanks!
