Unknown Operator Type Errors
   8568   8   1
Whenever I render out to Mantra in my current project, Houdini Console comes up with the following:
Unknown operator type: Object/geo
Unknown operator type: Sop/xform
Unknown operator type: Shop/vopmaterial
USe larger font: FFFFFFFFD30A1807
Despite the above error messages, the scene renders out perfectly.
As these messages are very unspecific (the renderer doesn't know what a geometry node is?) I have no idea what node(s) are causing the problem. The font message is also a mystery to me. It pops up every time and is quite annoying even though it doesn't appear to be affecting any actual rendering process. I'm using Houdini Apprentice 14.0.291.
Does anyone know what is causing this? Thank you.
Can you upload your project file?
This is my latest project file. It references external texture maps, so you will get some broken references.
Edited by - April 20, 2015 04:17:39
hmmmmmmmmm.
i saw this hip file.
any thing doesn't exist in floor and other nodes.
in other words these asset is empety and not install in houdini completely!!!
so even you get error in SOP level if you middle click in your interior geo nodes.
NimaNolan
hmmmmmmmmm.
Those nodes I made into digital assets, but within that same project file. I saved them out as .otl files, but, I created them from that project. I thought that saving a file with a digital asset already loaded into it would save the asset in it? In any case, on my system they are installed and show up in my file. Do I have to tell the renderer the location of digital assets or something?
Can you upload your asset too?
I should have .otl file to open in Houdini.
Otls
hello.
i ask and reaserch for this problem but nothing found mayby better you cantact with support team about this issue.
sorry.
remove or rename the houdini14 config folder and restart houdini.
