There doesn't seem to be an option to set a minimum radius for the connect adjacent pieces SOP - is there any way to achieve this effect simply?
I have points scattered on a surface and I want to connect random points to one another. Is there a better way to do this than with the connect adjacent pieces SOP?
Connect Adjacent Pieces minimum radius?
3462 2 2-
- Anti-Distinctlyminty
- 271 posts
- cwhite
- 802 posts
There's nothing built in, so I'd suggest submitting an RFE for this.
It's fairly straightforward to do in VEX using the pcfind function, though (or in VOPs with the Point Cloud Find node) - the Connect Adjacent Pieces SOP is just a digital asset, so you can take a look inside at what it does when the Connection Type parameter is set to Adjacent Points.
- 271 posts
