Emit with velocity relative to particle
5742 6 1-
- Simon Russell
- 166 posts
Hey,
So I've got a particle system that emits particles from a main stem. They emit at 137.5 degrees per particle (golden ratio) along the XZ plane. This is what's happening in the uploaded file and works ok.
But now I want to emit another set of particles from those sub particles but not on the XZ plane but relative to source particle. In the same 137.5 degree pattern.
Any help would be greatly appreciated.
- Simon Russell
- 166 posts
- pezetko
- 392 posts
- Pasto
- 80 posts
I also had to get velocity from sop, I could't find a way to control it with a POPvop, it seems to “set” the vel at each frame.
My file is quite clunky I guess, I don't know how to preserve a nice regular gold angle flow.
Pezetko your file is much more advanced.
Can you explain briefly how did you prepare the velocities ? Especially the quaternion and cross product combination ?
Many thanx anyway.
J
Many thanx anyway.
J
- pezetko
- 392 posts
Hi Jerome,
it's not my file, I just added single attribvop to prepare velocities (the green one) and removed circle (sin/cos) expression from pop source of third pop net.
I basically did same thing like you did.
I took normalized velocity and set it axis for rotation. Then I took vector perpendicular to this axis (result of the cross product) and rotated it around that axis by $F*angle (137.5 or whatever you want). This axis and angle (converted to radians (fixed filed is uploaded - I missed this in original file)) defines quaternion. That one is used for rotating that vector along branch and fed into new velocity.
Rest is normalization and speed maintain to keep everything correct.
- Simon Russell
- 166 posts
- Pasto
- 80 posts
