Grain Flow via a Funnel
   3246   2   1
I am not able to get the sand pass through a funnel - getting it exploding: https://vimeo.com/127637929 [vimeo.com] - the file is attached.
Is there a link to a successful demonstration, and helpfully with instruction how to do it?
Another failure I get is here: https://vimeo.com/127591250 [vimeo.com]
Funnel01.hipnc (403.9 KB)
Your collision object should be a closed surface. At the moment the resulting collision volume looks like the attached.
As a quickie fix (also attached) you can change the volume creation mode from Ray Intersect to Minimum and add a small Offset Surface value, but in the long run it is better to get used to creating closed surfaces for your collision objects.
funnel01e.hipnc (404.7 KB)
Wonderful! Thanks a lot!!
