Export obj sequence
   11182   4   1
Anyone know how to export an obj sequence running the trial version?
use ROP Output Driver (in SOP's)
set Valid Frame Range: Render Frame Range
set Output File: your_folder_path/filename_$F.obj
hit Render
under ROP (/out) there is the Geometry ROP that works the same just you can set the path to the geo.
btw: this nodes will work on any houdini version inclusive the apprentice one.
Thankyou!
After trying this it seems to calculate all the frames but when I import into c4d there is no animation. Any ideas.
made a simple test export hip file.
do you use for the obj sequence import in cinema4d a plugin?
http://lesterbanks.com/2014/09/obj-sequence-importer-2-c4d/ [lesterbanks.com]
obj_export.hipnc (49.8 KB)
