Crowd fur simulation
5689 7 0-
- Thezi Ndhlazi
- 1 posts
- Lukas Stolarski
- 35 posts
- tomtm
- 133 posts
- tomtm
- 133 posts
I asked myself the same thing today. But I also think, that a simulation per instanced crowd agent is not possible.
This would need a a dop per agent, this would be very heavy calculation.
I also doubt, that crowd accept vertex cache animation, but I'm not sure.
maybe an expert knows
I have another question concerning crowds. What is the new FBX feature with crowds, I can't see in 15.5 any difference to 15.0 Version…
Edited by tomtm - May 29, 2016 19:03:32
- Lukas Stolarski
- 35 posts
tomtm
I was thinking about starting a new thread about it, but I didn't
It's in the agent SOP (I've attached a screenshot) but I don't know how are we supposed to use it. If you e.g. put a path to a character exported from lets say Mixamo it still doesn't work - there are no clip names in the FBX so what should we put there? No clue. I hope help files will improve on that topic.
- edward
- 8081 posts
You need to use the clip named “mixamo.com” from Mixamo FBX files because that's what they name the animation. The problem is that I can't find a way to put multiple clips into the same FBX file so it's a bit tedious to fix the fact that all the animation clips are named “mixamo.com”. So I think one might need to manually use the Agent ROP to bake out the agent and then rename the clip files on disk to something meaningful.
- Lukas Stolarski
- 35 posts
edwardThank you so much! Sorry for replying so late Edward but I've missed your response.
I really aprreciate the pictures!
- Cesar050782
- 13 posts
