declaring vector in attributeWrangle and attributeVOP
   5005   3   1
hi,
how do you declare variable as vector xyz instead of float 123 in attribute wrangle node and in attribute vop? and create local variable?
in attribute wrangle, I'm declaring vector as v@attribute1, and in attributeVOP, I'm creating vector using bindExport…
in both cases, it's creating attribute1 vector as attribute1, attribute1, attribute1… how do I create attribute1, attribute1, attribute1? and it's local variable equivalent please? e.g. $ATTRIBUTE1X, $ATTRIBUTE1Y, $ATTRIBUTE1Z
thanks,
alex
v@attribute1 = 1;
setattribtypeinfo(0, “point”, “attribute1”, “vector”);
addvariablename(0, “attribute1”, “ATTRIBUTE1”);
and in VOPs you use Add Attribute to declare variable and set type info, then bindexport or setattrib to populate values
thanks!!
