slow motion explosion
   3424   3   1
Dear Forumers,
How would you go about simulating an explosion (but with many many subframes) but then put each subframe into a frame to get a slow motion explosion?
Not saying this is the right way to do it, but you could up the FPS to 240 in the Global animation options and then just play it up at 24 FPS and it will be 10 times as slow.
/M
Personal Houdini test videos, http://vimeo.com/magnusl3d/ [vimeo.com]
but it will still sim the same frames, just play back more per second
Yes you need to watch in flipbook or render it out and set that playback to 24 FPS after u have simulated it at 240 FPS.
/M
