hi Everyone!
I have made a sand simulation. I got two sand balls inside the dopnetwork that interacts with each other because they are connected by a merge node.
My question is if there is a way to activate the simulation 10 frames later only to one of these balls. I want the two balls starting the simulation in the same location but in different frames.
How to activate simulation in a specific frame?
15449 4 0-
- toad
- 38 posts
- Enivob
- 2658 posts
It is hard to say without seeing your file but look for a field called “Creation Frame”. By default it starts at the Start Frame of your animation. But you can right-click on the field and delete the value and type any value like as the start frame. Or add +10 to the expression.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- NewFlightDigital
- 1 posts
- Jwrecks
- 1 posts
Hi I have a similar question.
The Creation Frame worked to get the sim to start later in time.
BUT, I have a second object that I have holding while the first object collides with it.
Now Frames later I want to make the 2nd object to become active and be affected by gravity.
What is the best approach to this.
In a SOP SOLVER in DOPS I a have @active = 0; only affecting Object 02 while Object does it's thing.
I tried
if (@Frame == 72){
@stopped = !@active;
to make the second object active but no dice.
I tried
if (@Frame == 72){
- ibnuuncu10
- 1 posts
