Billowy Smoke Rendering
   9109   7   2
Hi there, I'm trying to render a Billowy Smoke simulation, but the final result has nothing to do with the simulation (I would like the volumetric effect from the simulation). Any ideas? Is it normal? Thank you in advance. Cheers.
I have a included a .mov and two .jpg. Cheers.
Alejandro
untitled.mov (3.0 MB)
looks like your density is too low compared to the viewport..try increasing the density scale on the shader to 10-50 range
The values in the Pyro shader should correspond well to the values in the Volume Visualization settings on the Pyro Object DOP that is driving the viewport rendering result.
Just copy/paste the density value and ramp value (if applicable) to the Pyro shader to match.
As well, density field/volume is just a mask that can be used to render smoke among other effects. How you interpret the density in the OpenGL display and in Mantra via the shader parameters is entirely up to you.
Thank you Jeff and Sidenimjay. I just added the Billowy Smoke Shader to my pyro object (changed density value as you told me), and now it is working. Cheers.
Now to get rid of that banding.
The default volume filter on the Object containing the volume primitives is most likely set to a box filter with a filter width of 1.
Please set that to Gaussian with a filter width of 1.2 and the banding should either go away or be greatly diminished.
Always do this if your volume voxels are about 2x the final rendered pixels or larger. Box filter is used when you have very dense voxels that are smaller than a couple pixels in the final render for crisper detail.
Where do I find the filter option?
on the geometry object Render/Shading tab, Volume Filter and Volume Filter Width
Cool, I start to notice the difference. Thanks for the tip.
