Can you load/save hotkeys. I work on multiple computers, but I do not see any load/save options in the shortcut pane.
Cheers
/Andreas
Load/Save Hotkeys?
4116 2 0-
- AndreasOberg
- 117 posts
- mandrake0
- 655 posts
the default attributes are under $HFS/houdini/config/Hotkeys/
if you have changed a hotkey you will find in your user folder the file HotkeyOverrides.
(Windows: C:\Users\USERNAME\Documents\houdini15.0)
if all the computers are in the same network you could setup a $HSITE then all your computers will have same configuration.
- AndreasOberg
- 117 posts
