wondows & otl scan path
   3579   2   0
Back to this sticky subject , which is a complete pain in wondows
HOUDINI_OTLSCAN_PATH=$JOB/otl;$JOB/hda;Rsettings/houdini/otl;&
$JOB is set > project is set > all the paths check out in the houdini scene variable dialogue > yet no matter what no otl / .hda will load using the above $JOB but Rsettings/houdini/otl;& works
Any ideas ?
Rob
Gone fishing
Hi, I wonder where and when did you set $JOB? Did you set JOB=X:something/something in the env file or somewhere else?
Andy
Hi Andy ,
I set $JOB in the houdini.env file and launch via a shell. I have also noticed other odd behavior on the windows platform. If you use the menu tools to set project you get a / at the end of the string. of course if your rendering $JOB/render you will get // which will not evaluate correctly. Its the first time in a long time Ive used windows to work on any project and the fact its windows 7 probably does not help.
I might explore launching houdini from a bat file in a project directory.
Rob
Gone fishing
