Culling Edge Faces on a Plane
   2291   2   1
Hi everybody,
I apologize if this is not the proper place to post this question, this is my first post.
Anyways, I am making a tool that creates a hexagonal grid. The tool is working properly- I give it the width and height of the grid and the length of the hexes, and its all dandy.
Coming from a computer science background, though, I'm trying to optimize it. I don't want any of the edge faces, as they aren't hexes. So the way I currently get rid of them is to create a delete node with delete by expression, with filter expression being checking all edge cases:
//top
//primitiveNumber % height
!($PR%ch(“../../height”)) ||
//bottom
!(($PR+1)% ch(“../../height”)) ||
//left
($PR < ch(“../../height”)) ||
//right
($PR > (ch(“../../height”)*(ch(“../../width”)-1)))
So. This works fine. The little I do know about Houdini, though, tells me there is a better way to do this. Manually checking each edge case for every primitive seems a little brute-forcey. There's always a better way! Any ideas / suggestions appreciated! Thanks.
assuming all your hexagons are identical in size, put down a measure sop to calculate each primitive's perimeter, then a blast sop with the group field using the expression
@perimeter<3
or whatever the size threshold you need.
Another way is to do it in a prim-wrangle; count the number of points in each primitive, if its not 6, remove the primitive:
int points = len(primpoints(0,@primnum));
if (points!=6) {
removeprim(0,@primnum,1);
Cool, thank you! My initial idea was to measure how many edges each primitive had, kind of like you suggested with the points, but I wasn't sure exactly how. Thanks!
