Hi there
So i've installed a 4gig gtx960 into an old dell t3600 3.6ghz quad core xeon with 32gig ram.
i've set the houdini env variables as below
set HOUDINI_OCL_DEVICETYPE=GPU
set HOUDINI_OCL_DEVICENUMBER=0
But when I run my fluid simulation which is using a particle fluid solver I see no or very little activity on the graphics card monitor.
Do only certain solvers use open cl? OR am I missing something here?
Nigel.
Houdini doesn't appear to be utilizing installed gtx960?
3860 3 2-
- nigelgardiner
- 48 posts
- johner
- 826 posts
nigelgardiner
The first step is to check About Houdini..| Show Details and make sure the OpenCL device is listed. Or with H15 run:
hgpuinfo -c
in a command-line shell to get the same information.
nigelgardiner
Only certain solvers use OpenCL, the main ones being Smoke/Pyro, Grains, and FLIP for pressure and viscosity solves. But you generally have to enable Use OpenCL on the solvers, often under the Solver or Advanced tab.
- nigelgardiner
- 48 posts
- aditya kukekar2
- 1 posts
