houdini engine in batch mode
   3291   1   1
Hi evryone.
I am trying to export geometrie from a hda in batch mode.
The problem is that I have a hang when maya start to open the scene.
I had the same problem few weeks ago in UI.
I fixed the problem switching off the “asynchronous Mode off”.
But in batch mode it don`t care of my preferences.
If somebody have any idea to switch off the asynchronous Mode when maya start in batch.
You are welcome.
mathieu
The asynchronous mode should be respected in batch mode as well. In batch mode, if you run:
optionVar -q houdiniEngineAsynchronousMode
it should show 0 for off, and 1 for on.
Maybe it's worth investigating why it's hanging in the UI? Does it hang when you clicked a button? Or is it hanging when the geometry is changing/computing?
Andrew / アンドリュー
