Can't access to geometry on OnCreated hda event
   2048   2   1
I want to access to my geometry on the “OnCreated” event of my HDA.
But it doesn't work on this event but work on the PythonModule (script function call with a button) ??
Here is the log for the same code :
- OnCreated event log :
  • OnCreated() currentNode = AtWr_BBox
    OnCreated() currentNode.type() = <hou.SopNodeType for Sop attribwrangle>
    OnCreated() geo = None
    - PythonModule log :
    geo = <hou.Geometry in /obj/box_object1/uvcubic1/AtWr_BBox>
    So, how can I access to my geometry in the OnCreated event ?
    Thank you.
Ok, As I understand, it seems that on this “OnCreated” event, my new created hda node isn't yet connected.
That's why I can't get geometry() from my current new node and of course, it isn't cooked.
I don't see any event on the list that match my need (= “OnCreated” + just connected) .
Did I miss something or do you know a workaround ?
Thanks.
As a workaround to simulate a “OnCreated” + just connected event :
I use the “OnInputChanged” event, and use an invisible toggle parameter to make sure I execute my operation once.
createdHdaNode = kwargs
thisIsTheFirstConnection = createdHdaNode.evalParm(“neverConnectedBefore”)
if thisIsTheFirstConnection :
#set parameter to false to never execute again this operation
createdHdaNode.setParms({“neverConnectedBefore”: 0})
#some stuff
I'm not sure if it's the best solution but it works and it's relatively easy to set up.
