Maya 2016 Extension 2 plugin?
   6426   3   3
Does the Maya Plugin support 2016 Extension 2 yet? If not, is there any ETA?
Tendril
Autodesk screwed everyone with that unannounced change in the API. With Houdini 15.5 due out before the end of May it might be sensible to maintain an install of Extension 1 as Extension 2 compatibility probably isn't SideFX's biggest priority right now.
Maya 2016.5 is high on my to-do list. I don't have an ETA, but I do hope to get to it as soon as possible.
Since the Maya plugin's code is available on GitHub, if you urgently need support for 2016.5, you can always compile the code.
Andrew / アンドリュー
Houdini Engine for Maya 2016 Ext 2 (2016.5) is now available in the Houdini 15.5 daily builds! Give it a try!
Andrew / アンドリュー
