Crowds change behavior from run to climb
   3582   3   0
I have a walk in place animation and climb in place animation of a monkey.
As soon the crowd hits a wall agents change the bahavior to climb but
the problem is, the particles direction still drag the crowd in Z-direction
instead of climbing up Y.
How can I tell the crowd solver to change the particle motion from Z to Y?
Look at the Flipbook in the attachement
Greets Tom
ip.mp4 (2.0 MB)
You may want to add another attribute to the system just for monitoring for your special case. You need the popseek to look at that attribute and change the way it seeks based upon that flag. So when you transition to climbing set the flag on the new attribute and then on the next frame the popseek can review that attribute. You could even come up with a switch that monitors the attribute. When it is set an alternate popseeksteer is used instead of the walking one.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
ok, thank you for your idea, I have to look how I can manage this in all these nodes ;-)
Attributes can be added to the crowd system inside the CrowdSource node. Just insert an AttributeWrangle before the OUT node and type in your new attributes.
You can then reference those attributes inside the CrowdSim network. For example change the CrowdTrigger (orange node) type to Custom VEX Expression and the node essentially becomes a wrangle where you can examine any attribute and use logic to set the @itrigger as necessary.
