Keeping pop attributes from birth
   3695   2   0
how is it possible to set an attribute in a wrangle SOP based on a group(inpointgroup), and keep that value, even if the group changes. I stumbled over this problem with the following setup.
I create a particle every frame and put it in the “Just Born Group”. All I really want now is to set some attributes at birth. But whatever I set in wrangle, gets reset to 0 if the particle isn't in the just born group anymore. What would be a good workaround for this? Here is an example:
What if I want to find the nearpoints at birth and keep these values, even if the position of the particle changes later on? I hope you get what i mean, maybe i am just overlooking something …
Thanks for reading.
keepvalues.hipnc (195.4 KB)
In sop context, there is no “history”, every frame the value gets recooked. What you can do is drop a pop wrangle in your popnet, and set the value there.
Thanks for the reply,
it works, I just had to remove the inpointgroup condition. Which leaves me with one question, what use is the just born group? Where does it make sense to use it?
