DOP Force Wrangle node
   3518   3   0
Can be used any wrangle node in DOP context ?
In DOP Network now we can use VOP Force node, but i cant find wrangle node for modify DOP data.
sorry for my english (
Hi
Can you use the Gas Field Wrangle node? It runs over each voxel.
-b
http://www.racecar.no [www.racecar.no]
Hmmm, i.e.:
Transfer data from RBD object to voxels -> make calculation via Gas Field Wrangle -> transfer data back to RDB object ?
I understand correctly ?
My opinition this way is not perfomance optimal ). Unfortunately, im have to use VOP Field ((
Hope, in 16 add Force Wrangle node….
Didn't know you where simulating RBD's
Try the Geometry Wrangle or the POP Wrangle and connect it to the Pre-Solve port on the Rigid Body Solver.
EDIT: Or a POP Force with “Use VEXpression” turned on.
-b
Edited by bonsak - Aug. 26, 2016 07:41:36
DOP-force.hipnc (235.5 KB)
