VDB Display Problems in Viewport ?
   8942   13   1
I'm having a problem whereas when polygons are converted to VDB they are displayed as solid white matte objects. I've reset my display options as well as toggled between varies viewport display options nothing solves the problem ?
【T】【C】【S】
Example pic? Perhaps try appending a Normal SOP to recompute normals.
I tried a normal SOP after the VDBFromPolygons SOP, didn't solve the problem, here is a screen capture.
【T】【C】【S】
normal sop is for polygon u can attach normal data to point, vertex, primitive, but not vdb ( either as sdf or fog )
you have to convert it first to polygon again before you can apply normal sop…
the question is what are you trying to do with that vdb?
my thought is… i think this is (youre seeing pure white )more of a driver problem…
I've seen tutorials where when the mesh is a VDB mesh and I'm sure most of you work the same, except me at this point; whereas the VDB mesh is a crude smooth shaded preview in Houdini viewport. I makes it extremely difficult see the results of VDB in the viewport when it's simple a white silhouette.
【T】【C】【S】
VDB=“Voxel Data Base” or “Voxel Data Blocks”
Voxel= volume metric pixel
AFIK theres no such thing as VDB mesh to become mesh it has to be converted…
may i know whats your graphic card and driver version?
again this is me just trying to help…
maybe a team viewer session?
I'm combining the terms into one and using the node as the terminology to describe VDB, my mistake.
Geforce Titan running nVidia driver 368.39. I'm up for a team viewer session ?
【T】【C】【S】
hi my skype id is patar napitupulu please contact me directly when you are ready…
Christopher R
Sorry, I misread what your problem was. That picture doesn't even look like a VDB being displayed, looks more like polygons constant shaded to me. Well, unless you have a super small voxel size compared to the size of your geometry I guess. Does something dead simple look like that too? eg. default box sop followed by a default vdb from polygons.
Edited by edward - Sept. 2, 2016 23:36:28
You are correct it does appear as polygons constant shaded, which it is; as well to answer your other question the same visual display in the viewport happens with a sphere converted to VDB with the node VDBfromPolygons ?
【T】【C】【S】
What's the reported video graphics info when you go to the main menu's Help > About > Show Details?
The Video Graphics info lists;
368.39.0.0 as the driver version
As for OpenGL version; 4.5.0
Hoping that helps ?
【T】【C】【S】
Well, I'm out of ideas then because it looks like your video card should have enough abilities to display them properly.
Edward - I agree, I can't put my finger as to why when anything is converted to VDB it's being displayed as a silhouette. I'm open to a team viewer session if there are any volunteers ?
【T】【C】【S】
