Hi, since VR omnidirectional renders (latlong) are used more often and i actually wanted to generate a projection from the an omni directional / spherical camera to project uv's. Unfortunately houdinis uv texture does only support perspective projection.
Any ideas appreciated.
Omnidirectional Camera UV Projection
3107 2 0-
- schiho
- 101 posts
- jordibares
- 655 posts
- schiho
- 101 posts
So you say instead of doing spherical maps, create a cube map and project cubic? I did a bruteforce solution for now, i am mapping a little sphere witht he uv's then i am shooting points from the target geometry back to the little sphere and transfer the uv attributes. Which works fine, but i wished there is a smarter solution.
