lines in fluid source
2484 3 0-
- Midasssilver
- 310 posts
- MrReedSmith
- 49 posts
Can you please elaborate on that?
Although judging by what you just said, maybe you have some stagnant smoke, dude to low vel.
Maybe what you could do is in your smoke/pyro solver, in the Advection tab >> Advection method, the default is set to Trace
You could maybe try using other advection methods like Trace Midpoint,HJWENO, etc
Maybe that might help
- Midasssilver
- 310 posts
Thanks for the reply! I'm fairly certain the lines are a product of too high of a division size, so what I am seeing is the voxel pattern. I'm finding it difficult to sim at a low enough division size on my work station. If I add enough noise to the fluid source, then the lines becomes turbulent enough that they are not visible.
- Midasssilver
- 310 posts
