Hi, is there a way to take the used in a color sop and make it the material color?
Ralph
Color sop to material clor
2860 2 0-
- Ralph Pinel
- 112 posts
- Enivob
- 2658 posts
Sure, on a Mantra surface that is exactly what the Use Point Color check box is for. To get the “true” color you will have to change the default Mantra color from off-white to pure-white. This will cause the incoming Cd point attributes to be multiplied by 1.0 in the r,g and b channels.
So make sure when you add a color node at the SOP level that is is applied to the points and not primitives. Also make sure you don't clobber the @Cd attribute latter on in the modeling process. To be sure place the color at the end of the network.
Remember to actually add a Mantra surface material to the object as well.
Edited by Enivob - Oct. 15, 2016 15:43:26
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- Ralph Pinel
- 112 posts
