i am trying to find a way to trace (create an outline) of a geometry from a direction.
so far i tried the ray sop with a dense circle surrounding the geo. but this fails on many features of more complex shapes.
i was thinking of maybe using the trace one but it requires either an image or a chop. not sure how i could use anything in a chop however. i would image i'd have to render with a pure white shader!? and then use the trace?
thanks in advance
Tracing Geometry from a direction
3835 3 1-
- spohle
- 5 posts
- Nima
- 471 posts
- animatrix_
- 5100 posts
You can slice the geometry using the Clip SOP and keep both sides, append a Group SOP for points before and after the clip, get the difference, convert this group to an edge group and then use a tool like this to turn your edges into a polygon curve:
https://www.dropbox.com/s/w785aogkd5j2uxf/PolyCurvesFromEdges_SOP_Animatrix.otl?dl=1 [dropbox.com]
- spohle
- 5 posts
